Old but not tired
Pardon me for "bumping" this two year old problem to the top. I did not fix it last year and would like to try one more time.
2000 GTX DI with relatively few hours, original owner.
The 15 amp fuse on the rightmost station on the mpem keeps blowing, even with the key off. The local shop cannot diagnose the problem and says I need a new MPEM. I sent the MPEM to one of the suppliers on this thread (in Minn?) and it came back as passed.
Narrowed the "problem" down to Harness #4, the leftmost one on the MPEM. No problem when the other 3 harnesses are attached but just attaching the #4 Harness blows the rightmost 15 amp fuse. No key attached. I tried with the two leads to the injectors disconected and same result.
I have read the stator posts but it does not blow when those harnesses are attached.
With Harness #4 disconnected, the engine will crank but not fire.
If the MPEM bench tested fine, can I assume that it is a short in one or more of the wires in the #4 harness? Any likely culprits?
