So I lost all power in the middle of the lake on my 1995 GTX (657), and had to get towed back in. I noticed the plugs were wet, so I took off the breather and saw fuel/ air blowing out the PTO carb.
I figured I had a RV issue or possibly a blown cylinder, so I ran a compression test with a 120/ 120 psi result. Turns out the issue was screw securing the needle valve pivot bar came loose, and I had a air leak on the pump side.
The ski runs fine now, but I am worried about the compression readings. From what I could find in here, it should be up in the 140-150s; doors this mean the engine is on its way out?
How far do I need to go in to fix this (e.g. new pistons rings and cylinder resurfacing)?
Thanks
Thanks
