12 volt low voltage
coastbuster
I have a 1999 GTX-RFI. Last year it sunk and the engine blew so I replaced it.
Everything works fine except that I am getting an error message on the digital
readout screen that says"12v low voltage". i checked the voltage coming from
the magneto and it is within range(45 to 70v). In the shop manual there is no test for the rectifier. it just says,"IF ALL OTHER READINGS ARE WITHIN RANGE
IT IS A GOOD BET THAT THE RECTIFIER IS THE PROBLEM" so I replaced it. I still get the message. Any thoughts?
Time to replace the battery cable lugs, solder & marine shrink-wrap. Clean & dielectric grease all fuse holders, wire connections. Check voltage. Start engine
and rev to 5500 rpm, recheck there. If over 15vdc, the Rectifier IS bad. Bills86e
still dont have 14 volts
i did all you said,even changed regulator,rectifier. still don't have 14 volts coming out of rr. i do have 40 to 70 volts ac from magneto. ? i'm at a loss. the worst thing is that i'm an electrician and can't figure it out. any more suggestions? dan
