Before I set the screws in a carb servicing,,,I take them off,,.remove the "O" ring, remove the washer that secures the "O" ring,,and the spring,,,,and then gently remove any crud on the threads of the screw,,,I also thread the screw into its orifice to see that it "seats" properly,,then I put a light coating of grease on the threads and the "O" ring,,
,when you reseat the screw, it should thread in easily and seat/stop easily and firmly.,,,if you are not replacing the "O" rings,,,take note of their taper for reinstallation..the pilot and high speed screws should rotate easily on their "t" s by hand,,,you should not need a screw driver,
