Okay,,stop,,i believe,,,it should be bolted to the side of the fuse module,,,it is securred with 2,,,10mm nylok nuts,,,the top one is easy to access,,the lower one is out of sit,,,,you will need a 1/4 drive ratchet, and short extensions,,,there are washers below the nuts,,they usually fall into the hull,,,no biggie,,,remove the positive starter cable at the battery first,,,that will help to free up the selenoid ,,,remove the 2 fuse holders from their posts,,,...this will allow you to bring up the selenoid to a way more manageable position.,,,hope this helps..
