07' GTi 130 4-Tec DESS/Start Issues
RWHall
Good day folks. Looking for a bit of guidance on an electrical / no start issue on a 2007 GTi 130. Here is the scenario and what i know thus far:
Plug DESS lanyard on - No beeps at all, gauges sweep, welcome aboard message flashes, gauges fade out & SEADOO remains on screen. No function at start/stop switch.
Pressing start/stop 5 times with DESS lanyard off does nothing/no beeps
This is what i have done:
- Battery is brand new and confirmed good & fully charged.
- power verified at solenoid and across all fuses
- cleaned all electrical connections at fuse block
- inspected and cleaned all electrical plug points
- engine cranks fine bypassing solenoid
- buzzer removed and direct wired to 12v verified working good.
- when i plug DESS lanyard onto another machine, that machine beeps once
- when i press the start/stop there is very faint noise at the buzzer.
I got the machine in this condition. The story is it operated fine and then just went dead over winter layup.
Where do I go next? Trying to avoid throwing costly parts at it.
You might look at changing the 30 amp relay, if you could swap it with another machine just to see if that is the problem.
