quickstrike
So I got the o6 gti put back together took it out for a spin and now I've got more problems.
Ski started fine in water and drove good but after 3-5 min I got a steady beep I thought it may be that I had no gauge cluster. But then the ski went to limp mode so I idled back to the dock and it was def overheating. The oil level was perfect before and I topped off the coolant with green freeze. I have one threaded hole by the impeller I think that's for flushing ?
Then two drain plugs but I also have two plugs on port stbd side aft there a rubber tube thing inside should I take these plugs out when I'm in the water??
