DTKCCMM
I have a 05 SeaDoo GTX I’m new to these skis. Hooked jump cables up not know.Ski Fired up, idles fine. Took it to the lake wouldn’t run over 20 mph. So loaded it up. Went home. Did some research learned about the two keys. ( Learner and normal ). When back to the lake. Try both keys same results. Came home again was going to pull the fuel system and clean. Started taking it apart and heard some noise. Fuel pump and a valve on the top of the engine was turning off and on. Without the key on. All the electrical Components r going crazy turning off and on. So I’m not sure if I fired the computer. Any help would be appreciated Thanks
