Fast Rider
I have an 05 Challenger that just went on the water from winter storage for the first time last weekend. 1 ride went great, second ride went well except for pulling the drain plugs when the boat was on the trailer resulted in a lot of oil dripping out of the drain plugs.
Upon inspection, oil is dripping from the bottom of the rubber grommet/bearing assembly where the driveshaft goes into the engine when the boat is running.
This is under the supercharger so it’s hard to see, but I can feel the oil leaking with my hand under there.
Does anyone think it’s possible that a clamp loosened up? Or is it likely to need the bearing/grommet replaced?
I’ve put together an order list and was hoping you guys could confirm I am getting everything needed, and maybe recommend anything I should also do while it’s apart.
Parts under the propulsion diagram:
- (33) C-clip. 271001575
- (34) support ring: 295501200
- (35) o-ring - 2 needed: 293300044
- (36) carbon ring: same part number as 34, do these come together?
- (37) Bellow: 272000183
- (38) Norma clamp - 2 needed: 293650077
Parts under the PTO cover/magneto diagram
- (42) bearing: 420832648
- (43) o-ring: 420631610
- (44) gear clamp: 420851653
- (45) gear clamp: 420853023
I’m planning to order thru the forum shop, but with no phone number to call to confirm these are the parts I need, I figured here is the best bet! Do you guys think I should do all of these items since I’ll have it apart? No salt water and everything visually looks like new.
I’m also thinking I may want to get the pump alignment tool and do that while it’s apart. Recommended? Anything else I may be missing?
