04 sportster LE DI dies when throttling down
jjbauer81
My boat will start fine, it will idle, and it will throttle up fine, but as soon as I back the throttle down to less than 2000 rpms, it dies. Even if I throttle up quickly before it dies, it does not keep it from dying. When I try to start it again, it will fire up and die and repeat this a few times before it starts back up again. And then the process starts over. It'll throttle up fine, but as soon as I throttle down, it dies. I put brand new plugs in it and it didn't help. I even drained the fuel tank and put in brand new gas, and it didn't help. Any ideas?
Unfortunately, when the injected engines have issues, it's hard to fugue out, without the dealers computer. But, I would make sure your fuel pressure is staying up, after a run. Also, I would check the TPS.
