04 speedster power loss
drunkenmaster
Having some issues with my speedster.
Engines rev up to 8000 on take off but the boat doesn't get up on a plane quick. I am only getting about 40mph out of the boat at full throttle. Should a 04 speedster w/ twin 155 hit closer to 60mph.
Sounds like you've exceeded the Wear Ring clearance tolerance in your jetpump(s).
Remove the venturi and use a feeler gauge to measure it. .008 as good, .040 as bad.
The proceedure is pictorized in your Shop Manual step-by-step instructions. Bills86e
sorry but i have a question. i have a 95 seadoo gtx do i have to mix the fuel and oil to 40:1 it has its owen oil tank. my father inlaw says it dont mater and that i need to mix
Your '95 GTX has a dual carb 657X engine, oil injection.
You can click on the forum sponsor "Seadoowarehouse" to see pics of the ski parts.
Wear ring tolerance
I can look inside the jet pumps and see that the tolerance is greater than.008Guess I need new wear rings!.
