04 RXP Question about a (Sensor) light coming on display at start up?
davidrxp
Hello to all,
I have a 04 RXP and now I get the word Sensor at start up and no VTS indicator bar in my info display and the VTS doesn't function. Also in my display I get a strange option FT 0.0 What should I do. I read on the board search that the Budds system might of turned off my VTS but would it give the flashing sensor? The ski runs great other then that. Any help will be greatly appreciated. I have a (sensor) light that flashes on my display when I first turn on the motor. Also the (VTS) or as I call it the electronic trim control/adjust button is not working or displaying anything on the Display screen which normally it is in the right corner. I am guessing here that the Sensor light that is flashing on my display at motor start up is related to the VTS Trim control not working am I correct? 2nd Question here is do you know how can get or view a repair manual (similar to the Haynes manual) for my 04 RXP motor that way I can replace/locate the sensor myself. Please advise me as I need help and also if anyone on here knows a good mechanic they recommend for me to use for my ski I am in the zip code 23117. Thanks in advance for your help as I am sure someone on here knows the answer and had a similar problem with their ski.
Dave
Also another question about me loosing RPM'S they are now maxed at 77-7800 as before they were higher. I had the (knock sensor campaign) done a while ago and was wondering if my RPM'S dropping could be due to not having this part (knock sensor piggy back adapter part number 278002050)? I have read on the forums that this part # above would possibly fix my problem with the RPM'S not being as high as they once were. Can someone here please advise me on this ? as well as I am sure some folks on here know the answer to this problem. Thanks in advance for your help.
Dave
Dave, I have the same sensor/VTS problem with my 2004 RXP, minus the FT 0.0. Works fine but wont start until the sensor indicator has stopped, about 5seconds, then the maintenance indicator comes on. Anyone out there know about this.
Thanks,
Shawn
The FT 0.0 is refering to the depth finder that you may or may not have.
Start engine and then press the "SET" button 5 times and the display will give you a code which will lead you to the problem area.
I strongly suggest you become a premium member. You can then access all of the factory service manuals. It will save you alot of money in the long run.
Good luck, DAWG
Your MPEM is not working properly and will need reset by a dealer with BUDS. The sensor reading is the depth sensor trying to get a reading but yours doesn't have one. Your MPEM thinks it's a GTX which doesn't have VTS so it won't function.
reply
Thanks very much for the info I appreciate it. I will go to the dealer then.
