brobertov8
Hi Folks,
After a wide service maintenance only left one issue on my ski.
When it is running WOT for a while (maybe after 1 or 2 minutes), I get a "A-TEMP" warning.
I got it 4 times in the last test...
No error codes were stored... even pressing SET 5 times or reading with CANDOO.... no error et all.
I could "touch" the JPipe almost no problem in these 4 errors times... it was not overheating for sure.
I only could see an "over temp" on the exhaust sensor - not a faulty, just the sensor records max and min, on the software -, according to CANDOO.... So I believe my Exhaust Temperature Sensor is bad.
Am I right?
I also checked the J-PIPE and cheked that 3 roles there... all three looks ok.
And I dont know if the clamp which locks the JPIPE to the waterbox, is ok. So I sent the picture below, maybe someone could tell if it is ok.
Thank You for any help!
Am I right?
