04 gti le rfi hard to start after it runs for 30 minutes
billybullets54
oK HERE WE GO
when you first put in water its hard to get it to idle until it warms up (1300-1600 rpm) then will idle fine. After a 20, 30 min ride you shut it off let it sit for five to ten minutes and wont start easily, you have to pull WOT to get it to start then its fine again till you shut off again. It uses twice as much gas as its sister ski, same model. Now this is a RFI (fuel injected). Sent out injectors to be tested, they are fine, we have changed spark plugs, we have changed volt reg cause the many trying to starts have killed it and drained the battery to nil. Spark plugs are wet with gas after shut off, and have a little black to them. the BUDS cant find any problems, and pressure (lines) are (all) good. no oil in the gas and no gas in the oil. ANY THING ELSE YOU NEED TO KNOW ASK.....
