03 GTX 4 tec positive battery cables
Coltrickle
I have recently purchased my 1st seadoo. It runs great and I am very please with it. However, it has sat tied to the dock for a month without being rode. We had family over for the labor day weekend and the battery has enough charge to turn on the gauges and beep but not enough to crank. I pulled the battery to charge or replace and noticed a fused wire laying behind the battery that has a red terminal on the end and I believe a 15 amp fuse in line that looks like it should be connected to the positive terminal. The wire also has what looks like a battery tender connection in line and the other end seems to run under what i believe is the main fuse block. Any Ideas what this is for and if it needs to be connected? I am thinking that it may have not been connected for a reason and am not sure about hooking it back up. Thanks in advance for all your help.
