03 gti le 787 rfi massive backfire after new top end im stumped
hypersniper2010
03 gti le 787 rfi. just did a new top end on it.
pistons are in correct arrow facing exhaust.
heads torqued correctly with new gasket,
cylinder cover torqued correctly with new gaskets.
rotary valve moving correctly and was never removed.
rave valves were trimmed for clearance and cleaned and new gaskets.
motor all put back together. have tried new plugs, swapped out crank sensor, swapped out throttle body and reset with candoopro. swapped out injectors, air sensor. after I swapped out the throttle body and reset the tps I wient to start it and it backfired so loud and hard that it blew the hoses off the exhaust.
candoopro shows no active codes..
I am stumped and at wits end :facepalm::facepalm::facepalm:
