Duane72
Morning everyone. So I've been tackling this GTX for a friend. I posted some of the issues in another thread, but it got tied up in focusing on the leaking oil filter. http://www.seadooforum.com/showthread.php?65541-Oil-Filter-Cap-O-ring-Blows-Out I figured that out. Some bonehead (might have been me :facepalm: ) put the oil filter cap orings in backwards.
So now, ZERO oil leaks, oil level is good. But running it even on the trailer with a hose hooked up, the oil warning comes on and puts it into limp mode. No codes are given from ECM. I put an oil pressure tester on it at the test port below the oil filter and I'm getting 70PSI at idle. It creeps up to 75PSI-ish when I slowly rev up to and passed 3000RPM then gives me the oil warning light and cuts to limp mode (rpm drop and limited). I shut the water off, shut the motor down, pull the key and it starts all over again next time I fire it up. I tried this with the oil filter installed and uninstalled with no difference in pressure. Same with dipstick seated and unseated.
FYI: We just rebuilt the entire pump shortly before all this nonsense. The skis only got an hour in it maybe since. New wear ring, bearings, carbon seal, etc. so the driveshaft WAS out of the ski. Have NO idea how that would affect it but I'm covering my bases.
There is nothing in the service manual troubleshooting for high oil pressure. Only low oil pressure. I found that odd. But that leads me here anyway. ANY suggestions? Thoughts?
