Thanks. Will check it today after work. I'll post a pic of the motor later maybe you can verify by looking at it. It does have injectors but my brothers 01 di has a black cover over his injectors that says direct fuel injection and mine don't .not sure if mine is missing but vin says it a rfi.If it was your wear ring the engine would hit the rev-limiter You need another 400-500 rpm. I hope it's not a DI. I really like the RFIs. Check the water control valve on the water box check to see if that is leaking and the diaphragm is in good condition. That will cause you that type of RPM Loss. Good Luck !
Looks the same but don't have the black dfi piece over the injectors. Any suggestions on brand for new ring and impeller. Also what should I be getting as far as max rpm and speed. ThanksYour wear ring is trashed and your impeller leading edges look bent.
Pull the pump.
High RPM and low water speed is always pump related.
Does the top of your engine say DIRECT FUEL INJECTION? If it does that is a 951 DI if not it is a 951 carb or 787 RFI.
You might have RFI then. Take a picture of the engine.
Impros can refurbish your impeller. Wear rings from PWC Muscle, Seadoo warehouse and OSD Seadoo
I guess I have the di? What should I be getting on rpm and top speed?You might have RFI then. Take a picture of the engine.
Impros can refurbish your impeller. Wear rings from PWC Muscle, Seadoo warehouse and OSD Seadoo.
DoThanks. Will check it today after work. I'll post a pic of the motor later maybe you can verify by looking at it. It does have injectors but my brothers 01 di has a black cover over his injectors that says direct fuel injection and mine don't .not sure if mine is missing but vin says it a rfi.
So you think wear ring and impeller will fix my problemThat’s definitely a 951 DI Direct Fuel Injection.
2002-2003 is 51-52 mph top speed.
Max rpm should be around 7,000.
Impeller will not be here til next week putting wear ring in today. Will my old impeller mess up my new ring? Should I just wait til impeller comes and do it both at the same timeYes fix your impeller and wear ring no matter what.
New spark plugs and fuel filter.
I would wait because I am lazy like thatImpeller will not be here til next week putting wear ring in today. Will my old impeller mess up my new ring? Should I just wait til impeller comes and do it both at the same time
