01 Kaw Ultra 150 wont start...
Regi Pinto
The engine cranks super fast if I take all the spark plugs off, lots of compression... Put the plugs back in and won't turn or cranks really, really slowly. The starter is the second one after the first one burnt out. Got new Spark Plugs and the Battery is less then a year old, always let it charging on 2 amps all night long before try again. There is oil getting into the cylinders I can tell by the wet plugs. But even like that it started about two weeks ago just using the Choke and holding the start up to 30 seconds ( WRONG WAY) now I'm not doing this again.
Please don't tell me to check the carbs, I already clean it and order the rebuild kit, to be safe.
I just need to know why is so hard for the starter to turn the engine normally?
Is it possible that the crankcase is so flooded that doesn't turn?
Could be something on the exhaust system?
Need some help urgent. Thanks.
