I can't disagree. It seems like a semi hard line, but I wasn't sure if it was because the heat and pressure hardened it. I'll see what I can find out at my local shop. Was there ever any comments on why it ruptured or is it just assumed to be age related?Extensive recent googling on air compressors while troubleshooting my ski revealed several folks that rupture that line over and over again. I have not dealt with that (yet) but you are not the only one. Believe it is a special high pressure line that you should probably source from SeaDoo.
Following this. A lot of good info here.
I'll chime in on the after market fuel pumps. I bought one from High Flow a while ago. I now have 5 in my garage. They have great customer service. None they sent were able to put out the right pressure so when you call and tell them that, they just keep sending more pumps. I gave up after giving them an additional $30.00 for the so called high pressure pump.
Cleaning the OEM pump and changing filters usually brings a non working pump back to life. I believe these pumps would last indefinitely if kept clean.
Welp... Just spent 3 hours out on the river with a perfect running machine. Then bleh... She quit. The same tube ruptured. I moved a few tubes around out in the water to be able to get one long enough to reconnect the compressor to the rave solenoid. No bueno this time. Couldn't get the pressure over 60psi. I suspect the compressor is shot. Heating up enough to melt the line and now is just bad. I'll rebuild it tonight and see.
I'll try to take some pics. At least one of the threads I saw said sticky/malfunctioning RAVE valves could be the cause. They either stay open or closed and cause heat to build up and pop that line. A dealer fixed theirs by fixing the RAVE valves apparently. I might be able to get to this today hopefully.Post some pictures of the compressor rebuild if you don't mind. I'm curious about that. Good Luck with it.
Question do you think you might have a water flow problem on the compressor? Even if it is not putting out there is no reason for it to get real hot is there? Usually loose is cooler.![]()
Glad you found the problem. Hopefully now you can fix and enjoy.And the last few pics of the carnage:
View attachment 50149View attachment 50147View attachment 50148View attachment 50146
