jammin777
hey guys after reading 68Ragtop's thread on this subject i've found i have the same issue with one of mine
(787 rfi)
today messing with my engine, i decided to hook a hose to my check valves on the rotory cover, one of which i can easily blow air through it (by mouth) and the other the not at all but can with a little compressed air. the bad one tells me that oil can leak right on through while sitting. am i right on being concerned? also how much psi to be able to blow past the check valve? how much pressure does the oil pump produce to the little lines that go to the rotory cover? and finally, will the part numbers that 68ragtop posted work on my 787? 420956510
thanks 68ragtop for the tool idea as it looks like i'm going to have to make one myself.
PS. should i use a sealer if i replace? and what kind?
