I have been running a 99 XPL for a while till my rectifier went a few years ago and melted the MPEM and part of the harness in the process. I purchased a new MPEM and harness, but then I let the ski sit for about 5 years. In the mean time I picked up an 03 XPDI hull that was in really nice shape. I wet sanded and polished it and repaired the Gelcoat with a repair kit from Spectrum. The gel coat came out pretty well for being done by a rookie. So I have started reassembling the ski and I am stripping everything from my 99 and putting it in the 03. One reason I didn't try and clean up the hull on my 99 was that it was very faded and the deck was painted by the previous owner and the paint was starting to lift. Anyway, so far everything has been pretty straight forward except for a few of the water feed hose from the pump was bigger. But my next question is the engine always ran strong till the rectifier went and before I put it back in I am going to check compression. But I am concerned about the bearings for the balance shaft being questionable. Should I just go through the whole engine? Or is it easy enough to remove the counter balance shaft and just replace the bearings?
Thanks,
Chris
Thanks,
Chris
