interrider1
Hi to everyone,
I'm new here. I have a 1993 seadoo xp 657, i really need some expert advice. This ski has spark.. No Start....i've replace the cdi box ,coil,rebuilt the carbs,the computer,starter,vts. check fuses. i changed just about everything.The ski will sometimes run than sometimes won't .i did notice gas sometimes when cranking it, gas spits out of top of carb, when it doesn't start. i also change the intake, put gas in carbs still won't fire.even gas in cylinders .Check timing,fine. I even change the tether switch.. i have service manual. the cylinders are in range. i've check switches with ohm meter..i've done everything...sometimes it runs sometimes won't start...the spark plug tester shows good spark.. I'm really lost...I really need help, I've done everything i know...so someone please help me. I've been all over the internet, reading, nothing.
I really need expert help on this problem. Thanks Doug...
