Would a bimini from an 1800 Challenger fit a 14' Challenger?
Well I bought an 1800 bimini.
It was a couple inches wider where it mounts, but it easily attached to the stock side mounted attach points. Although it fits, I think I am going to buy a smaller one. I like the look of the small factory top. The 1800 top is not only wider, but longer so it your looking for a lot of sun coverage, it may be the way to go for you if you have a 15' sea-doo. With the 1800 top down the stock cover has a hard time getting over it on one of the corners.
Hopefully this will help someone else out one day that tries to do the same thing.
Check out the Taylor Made AnchorShade. I'm thinking about getting one of these for my 98 speedster since I'm not a big fan of bimini top sails on a small boat and will only be using it when stopped.
Thanks, any idea what size, or the dimensions I would need. I cannot find the stock bimini dimensions anywhere.
