IDoSeaDoo
Hey everyone. I have had particularly bad luck with motors going out on me in my 97 SPX. The carbed 787 just won't hold up, despite me putting in new new and remanufactured parts and doing everything by the book. I've been trying to keep a stock ski, for the sake of reliability, but I just can't get it.
Several people who have rode with me commented that I do ride my machine hard, so this brings me to my question: how do I build a bulletproof ski, which I can ride the hell out of and that will hold up, even with aftermarket parts?
At some point, I plan to build a ski with the following parts:
SpecI Factory Pipe
Novi carbs (reworked OEMs by NOVI)
Aftermarket FAs
Water Injection
97 SPX waterbox
MSD Ignition module
(maybe) a port job on the cases and jugs
I might or might not raise the compression. Not sure if there is a huge benefit to that. Seems like that would just compromise longevity more than anything.
Anyway, with this setup, what crank should I use? Previously, I used remanufactured cranks by some hack on ebay. They used WSM rebuild kits and the first crank lasted 20hr, then a conn rod split in half and destroyed half the motor. The second ran great for most of the season, then at the end, I got this condition where the PTO plug keeps fouling out. I'm suspecting that it lost an oil seal. It's getting extremely hard to find new OEMs. Some parts vendors offer an OEM reman for ~$430 or so, and require a core.
I used to use WSM pistons, but would always find scored pistons and cylinders after just half a season. I heard that WSM expands more than other brands and actually becomes out of spec. I forgot what the conditioins were for this, but that it tends to happen if you don't "warm the boat up properly"? Anyway, I want to use anything BUT wsm in the future. What do you guys go to for pistons, and about how much should they cost?
Any specific brand for rings? I can only seem to find RIK. Not sure if any of my problems could be attributed to them sticking or maybe it's just the piston over-expanding and gouging them into the sleeve. Sometimes I find broken rings after an engine failure.
With $450 for a crank, and another $200 for pistons (plus $100 to bore) and another $70 for gaskets, we're up to almost what a reman motor would cost from SBT or SES. Now, some of those can even come with a warranty.
If it were you, and you were building this machine, what parts would you use, and where would you get them from? What would you expect to pay?
SpecI Factory Pipe
Aftermarket FAs
Water Injection
97 SPX waterbox
MSD Ignition module
