Those plastic things are your RAVE caps. The RAVEs are exhaust valves that change the size of your exhaust port, allowing the ski to change the power curve. There is a spring inside and it keeps them closed until the RPMs are high enough and the exhaust pressure overcomes the spring pressure. Once open, the engine can breathe more freely and achieve the desired performance. Keeping those valves closed allows you to faster build up torque and scavenge some of the fuel/air charge that normally would pass right through the cylinder.
