Rabid Active Member Sep 3, 2017 #1 One side of the wear ring has a groove and the other is flat. Which side goes into the pump?
racerxxx Moderator Moderator Sep 3, 2017 #2 Flat goes in and the groove (the lip) is to seal it to the ski, but you should use a neoprene seal too.
Rabid Active Member Sep 4, 2017 #3 I got one with the delrin ring...thanks for the info...problem now that there is a ton of debris from Harvey in the lake..don't want to destroy ring.
