TLH101
I think I already know the answer to this, but wanted to run it by the forum, before I rush out and replace the beeber.
Sometimes the beeper does not sound, when I put the DESS key on the post. Cleaned the button in the middle of the post, and the contact in the key. Other times, everything works fine, and it beeps as normal. When I first noticed the problem, I could ground the heat sender wire, and it would beep. Yesterday, it would not beep when attaching key, so did the ground test, and got a very faint tick sound. I just chalked it up to a bad beeper, but today, it works fine. I have checked all the connections.
Does it sound like a failing beeper, or do I have some other problem???
