Vent location questions..HELP
65deuce
Looks like the previous owner (95 spx) incorrectly routed some of the vent lines, namely the fuel vent that should go to the steering area, this was plumbed over to the oil tank check valve. A small nipple coming off of the VTS motor with the "hydrophobic vent" :confused: was plumbed up in the steering. here's what I have for venting now:
Fuel Tank, vent line T's off of the pick up one side out to the hull, the other to the little grommet up by the hood latch.
Battery to hull
Where does the oil tank vent go?
Where does the vent on the VTS motor go, this has the VTS that is opposite the fuel cap
I am not sure about the VTS, but the little check valve on top of the oil tank does not go anywhere. That is the end of the line for that one.
