Darryl stahley
A while back i changed the inline oil filters on my 2 787 XP 's ever since I've Been getting oil in the bottom of both of them so I'm figuring what ever is causing it on one is what's causing it on the other , cleaned out the hull today and I jacked up the front of the trailer so if there was a leak it would run to the back , I had a very small stream of oil and water coming from under the gas tank which I believe was from the clean up then the hull was dry up to the front of the motor at the back of the motor there was a pretty good oil mess so I'm thinking it's coming from the oil line that runs out of the top of the oil tank and under the left side of the motor , does anyone know where this oil line leads to ? It's almost impossible to get your hand under there to see where it leads can only imagine what a bitch it will be to change this line if that's where the leak is
