WaterEnthusiast
Hi,
I recently purchased a 2008 Sea-Doo Wake 215 and noticed that the trim isn't working properly. When it is in the up position, I can press the VTS buttom to bring it down, but the up button won't bring it back up.
When opening the VTS housing, it was clear that some water had gotten in the VTS housing since there was some rust on the exterior of the motor. However, we replaced the trim boot that sits outside so no water should get in anymore. The motor, although rusted a bit, is working properly.
If we manually turn the worm to a certain position, it seems that the sensor will "catch" that it is down and then the VTS up will work. Basically, the motor works in both directions, so I do not want to change it at this point.
I do not have a good grasp of how the mechanism and the sensor and the circuit board (??) work, but the seller basically explained to me that there was an easy fix with relays that would bypass the electronic system while still showing the trim position on the dashboard.
Unfortunately, this forum doesn't allow short keywords so I can't search for VTS so I feel I am probably missing out on the good posts that would help me.
As a side note: My budget is limited so if I can avoid it, I prefer not to replace parts that could still work.
Any advice on what could be the problem, and how to fix it?
Thank you very much.
