Straight Fittings
cj3737
Can someone explain the straight fittings that are spliced into the fuel lines going to the carb of the mid 90s skis? Are they a check valve? If not, whats the purpose?
They are just a plastic connector that was probably used on the assembly line so they could fit different components and different times. You can keep them or loose them with no issues since they are straight through plastic tubes.
