Sportster 2003 LE Gauges Problem
dermot
Hi All,
I have problem with the Speedo & Rev counter,
First problem happened with the speedo,instead of the needle progressing normally clockwise from 0 to 55 MPH, it does not register anything till I do about about 40 MPH and then it goes anti clockwise (the opposite direction) past 60 to 45MPH stays there, does not move if you go any faster, if you slow down a bit it goes clockwise to Zero. When the boat was out of water I aimed a pressure washer hose at speed paddle with similar results.
Then about a month later the Rev counter started to do more or less same thing.
any help would be apreciated
Dermot
