There are more glitches in the level. First, there is another spot by the entrance where the water just lets you fall through. Yet another spot is by the broken vent water fall near the underwater part. Then there's the spot where you see the giant t-rex bones and the glass paneling. jumping the seadoo through the non solid glass will allow you in some parts to let you fall through depending on how far the jump get you. Once this happens there's a chance you get to fall into "heaven" where you're below the level, but yet you hit water for no reason but everything is white and clouds. Wipeing out will put you back on the course.Also, if you go through the waterfall the right way by the same place you can fall there's a possibility you can have an invisible rider or be completely invisible.Dino Dominion
