Spark Trixx 2017 (How to flush?)
adiSea
Hi I’m new here I really need this help from you as It’s driven in the sea water almost all the time i have the Seadoo flush adapter I connected it but I’m not sure on wich side I need to connect left or right check photos the left has cap on the hole and the right one is opened, I also removed the cap on the left side it has same entry as right side
Please help urgent. Thank you.
Please don’t flush anything yet on those holes - give me a second to look at your manual because my flush port is in a different position where you posted it
I did it on wrong side instead on flush port it beeped i stopped the engine not more than 2 minutes i released the water inside after i realized i did it on wrong side i raised up the trailer for the water to go out and i removed all the water but today morning i started to see if everything ok it started normally but now check engine light is on i checked the oil level everything is fine what should it mean
Man I am sorry you did that, that is not good, you were running your engine without water connected to your flush port - you could have burnt something up - let me look, that’s why I tell people don’t do anything unless you triple check it on the manual and internet because you could burn carbon ring seal and other components, let me look it up and verify.
Thank you brother I tried but nowhere to find that info someone said to me “Probably because you over heated the exhaust. Should go away once you put it in the water.”
