axle
I have bombadier 2004 gtx di seadoo. It was running fine until it suddenly wouldnt idle . It will fire about half a dozen times before running but only if revs are kept up high. Took to seadoo mechanic and he said fuel pump buggered and only had half pressure. So I bought new pump and installed but does exactly same. On the screen when it is running it says mantainance, Any ideas what to look for next. I would have thought if pump only half pressure it would idle but not run at high revs. Maybe someone has had same problem... Thanks
