Seadoo bombadier sucked up tons of rope
Hp officejet
Unknowingly I took the grate off, then I used a knife and got all of it out. There appears to know be a crack in the hull where the rope was pressing. The impeller shaft won't move at all. I have not tried to start it since this incident happened.
Send a picture of the crack. As for the drive shaft it's probably bent, take it out and roll it on a flat surface
Pull the pump out. Check that the impeller spins evenly. With the spark plugs removed, try to rotate the driveshaft by hand inside the hull. You may be able to tell if it's bent or not before fully removing it.
