To SportserJoel or anyone who knows
I read in SporsterJoel's thread the following add on's to improve speed.
-upgrade supercharger wheel to a 9psi one If you go over 9psi of boost you'll need the mpem programed by powerchip think it about $500 even if your all stock you can still get an extra few more mph from the powerchip reflash.
-upgrade the innercooler
-impeller with these upgrade 15/20 should work best
I have some questions. First is there any benefit from improving the intercooler without replacing the supercharger wheel? I am concerned with boost exceeding 9psi and not having quick or easy access to reflashing the powerchip so I may avoid increasing boost if too risky. 2nd, is there better value in the powerchip reflash than replacing the supercharger wheel and the intercooler? 3rd If the impeller size is changed does the wear ring need to change also? The stock impeller size is 14/19 and the recommendation is to go to 15/20.
Thanks
