Sea-Doo RX 2002 I mixed gas with oil,, how do I drain all oil
assuming you are talking injection oil? If so, remove the oil tank which is fastened on top of the gas tank. use hose pinchers to block oil from running out, disconnect hose to oil pump, disconnect filler tube from tank to top of ski. pull it out from the front.
