I have a challenger 1800, 98' and one engine has no thrust at all. It just stopped working on water when in motion and the engine just sounded like it stripped something or a pin sheered in the impeller shaft or something. It will start fine but idles very high and if I give it gas in or out of gear it revs very high very fast and spinns at high rpm's for a long time. There is no thrust at all on the one engine. I took it out of the water and found a piece of platic tie from a newspaper bundle sticking out of the jet. If it did break something how can I check? Any ideas on cost to fix?
Thank you,
josh
Thank you,
josh
