I recently purchased a 2002 Sea Doo RX-DI, with 120 hours on it. The compression is good, it idles fine, and top speed is fine. However, it seems to bog down in any of the following situations:
Basically, it seems to stay around 4000-4300 RPMs no matter how much throttle your giving it. And then if you play with the throttle, within a few seconds, it surges forward to the correct RPMs. When you accelerate from idle, it seems to be fine.
We changed the fuel filter and checked the fuel pressure. And then we cleaned the RAVE valves, and changed out the o-rings/gaskets, which didn't help any.
Does anyone have any ideas of what to try next? Thanks in advance!
- Giving it a lot of throttle, letting go of the throttle, and then giving it throttle again
- Right after jumping a wave (when you hear the engine rev higher because your out of the water)
- When your accelerating out of a power turn
