Running rfi cases carbed
None really but if you want to take advantage of the case cooler then you need to incorporate that into the water flow.
Can I “Y” the main cooling line
Or tap the pump for another
Cooling line?
I’m getting ready to put this engine together and see grumpy old guy
has a set of Rfi cases and bein in AZ
more cooling is always good...
Yes you can do that but you don't want to rob too much from the main cooling line. Normally I see the case cooler last in line. The cylinder drain will go to the cooler and then out of the hull. Tapping the pump for it would be overkill.
