The machine idles/runs rough and hesitates on take off up to 4000rpm. I'm thinking fuel problem. The new water seperator after only 1 hour already has gunk in it. And the one fuel filter down at the carbs (I could get at) is at least 50% blocked. How do you remove the carbs? Do you need to remove the exhaust, cause i tried to and I can't get the last remaining bolt out, that's hidden underneath the manifold. Any suggestions?
