Rotary valve and counterbalance crank lub, break in oil?
Vegas
What lub are you suppose to use on the valve? I saw somewere where you use Molykote and elsewere injection oil. Do you just coat it?
ALso the resevoir for the counter balance?
And do you need to add extra oil in gas for break in?
Thanks
Add 1oz of 30 weight oil to the balance shaft.
The rotary valve gets oil from the oil injection in the intake.
Add extra oil to the gas to get a 32:1 mixture
