Real Pain
Here is what I have found doing mine..
1) Rear bottom has bolts from hull into seat, you need to reach between the gas tank and the hull.. (lots of Fun)
2) Rear upper has bolts from engin compartment into seat
3) Bow seat pad is on clips pull directly upward to remove
4)lookout seat you can reach the nuts on the upper pad from the cooler..
5) front seat on drivers right has a push type clip toward the center of the boat, pull hard and then push the other side toward the front and it should release
5) There is now a passage way exposed you can reach the nuts on the top of the front seat..
6) Arm reast on back you need to put your hand through the cup holder, there are two nuts on each.. (this is a REAL bitch)
This all I have removed so far, I think the bottom have clips that should pull straight up..
