kappachampion
Hey guys,
I disassembled the jet pumps on my 97 speedster today because I was having some cavitation issues (high RPMs no thrust). The wear rings have some wear, but I'm not sure how to tell if it is irregular. Some groves seem to be deep (maybe a mm or 2). There is a knick in the wear ring in one location and the impellers have significant damage along the leading edge (I think my brother got into some rocks). There are several dings along the edge, some being several mm long and a couple mm deep.
Do you think these can be repaired or should I just replace them? Anyone have any idea how much repairs cost vs replacements? Is there a better impeller than stock that I should just upgrade to?
Also, while I was down there I noticed, the white plastic "driveshaft shield" (don't know what it is really called) was missing from one engine. I plan on replacing this but was curious if it could be contributing to the cavitation issue.
I also still have a studder in my throttle at about 1/3 throttle. it goes past it just fine but if I pause there the RPMs will drop. Any ideas?
Some other random questions:
I need to replace mu scupper valve any suggestions of the rubber vs pingpong ball ones?
I need to repaint the steering nozzle on one of my jet pumps (it is starting to corrode) will standard paint work fine, or is there paint for marine use?
Anyways, thanks for the help. I'll keep researching other cavitation problems and things I can check.
