D docster Member Jun 2, 2016 #1 Any tips on removing old decals. Mine are pretty brittle and just crack into super tiny pieces. I tried heat to no avail. Other ideas?
racerxxx Moderator Moderator Jun 2, 2016 #2 Most guys use a heat gun to soften the decals. I do that and use a strait blade to start. But you have to be careful you don't dig into the gel coat
Sloanman7 Active Member Jun 2, 2016 #3 i found some plastic razor blades a lowes works pretty good to get started and once decal is off i used goo gone to wipe the residue off.
blairwill4 Active Member Jun 3, 2016 #5 3m eraser wheel is hands down the easiest way ive been able to do it.
Spimothy Leary Well-Known Member Jun 3, 2016 #6 < had bad luck with the eraser wheel, bought two and ended up reselling them both. heat gun has been my tool of choice for yrs. plastic razor is a good idea tho.
