FWIW, most always it doesn't matter which yellow combination is connected except maybe one case I think, for OEM rectifier/regulator 278000443 the center yellow is connected internally inside the regulator to the red output lead. You can test for continuity between this yellow wire and the red wire to confirm I still don't think it matters which yellow goes to the other though, but that's how the factory connected them. I recommend this way though, b/c the center yellow would go to center tap of the stator coil.
Red wire goes to battery +, through a fuse (10A?) 1st then eventually battery + terminal.
Metal case of RR MUST be grounded.
Center yellow wire of regulator (in the case of OEM Factory 278000443 regulator) will always be hot with 12V DC from battery,
I used this 278000443 regulator to convert an old non-regulated battery killing over-charger into a nice regulated charger, gave it a new purpose instead of destroying batteries. See attached diagram.
But you have a 2nd ski to compare, so this helps.
Lastly, buzzers do die, so your buzzer might be dead!
