rebuilding the jet pump on a 1996 Seadoo GSX
cmeseadoin
Hey guys,
I have a 1996 seadoo gsx with the 787 and she's got about 290 hours on it. I have owned it for the past 11 of it's 13 years and it has been immaculately cared for and only run in fresh water. It looks like bran new inside and out, but it is time for some work that has never been done. Part of what it is.... I am installing a new wear ring as I took off the nozzle and pump and there are a few areas where the ring is gone but overall not horrible. I don't think it has ever seen a new one. I have the pump on the bench and have ordered all my parts from SBT including a tool to pull the impeller. It seems that all I do is unscrew the impeller by locking the flat shaft of the pump in a vice and turning the tool counterclockwise as to unscrew. I cannot wait to see how tight that thing is screwed on as the whole time you throttle up she's trying to tighten more LOL! Once I get that off, I am going to have to saw and cut carefully the old wear ring out.
(P.S> I know this is a total no no in most cases, but if I get that pump shaft locked in a vice, is there any harm done by running an impact gun on the impeller removal tool in several quick sharp blows to break the torque seal and break her loose?...With the tool in there, the splines should be able to hold up to that?)
Another question is, once I get the impeller out, does taking the impeller out mean that it automatically needs a jet pump rebuild and to replace all bearings in the pump that are behind that impeller? Probably a good idea with 290 hours on the ski? How do you tell specifically if this needs to be done? Also, I have ordered up the jet pump rebuild kit for it, but it seems that special tools are needed to pull and install the new bearings/seals and whatever else is behind there. Can someone tell me what tools this is and where I can purchase them? I am highly mechanical and I can do the job if I have the tools. I did not see jet pump service tools on SBT but maybe I did not search correctly?
Any information would be greatly appreciated...thanks guys:cheers:
