tturbonegro
Quick carb adjuster question...
951 motor (99 GSX-L)
I know wich one is the idle adjustment...
Wich ones are High and Low speed?
The top adjuster screws are High speed..is that correct? And the ones on bottom of carbs that can be felt but not seen (while already installed on motor) are the Low speed?
Sorry if that's a dumb question but just need to double check..
I think one is good and the other isn't matching it..so I want to mark where the good one is set, turn it all the way down while counting how many revolutions I make, then turn it back to it's original setting, then make the other one the same...the low would be easy to do this as they are right on top, but it's high speed I'm having issues with...how would I go about marking the ones on the bottom under there? A mirror?
